1998 Mercury Sable Alternator
1998 MERCURY SABLE
DEVINTHEREAPER
  • 5 POSTS
Engine Mechanical problem
1998 Mercury Sable 6 cyl Two Wheel Drive Automatic
What is the difference is size between the 110 amp alternator and the 130 amp alternator on a 1998 Mercury Sable 3 liter engine?
Mar 29, 2009 at 7:41 AM
MERLIN2021
  • 17,250 POSTS
Physically the same size, just higher output. With the VIN, call ford and they will tell you which one yours came with. Parts dept!
Mar 29, 2009 at 8:15 AM
DEVINTHEREAPER
  • 5 POSTS
[quote:f6f3bfd8fa="merlin2021"]Physically the same size, just higher output. With the VIN, call ford and they will tell you which one yours came with. Parts dept![/quote:f6f3bfd8fa]
is there any difference in the case? I want to put the 130 in my car if there is no difference in the case, and e-bay also has a 180 amp one available for the 1998 Mercury Sable 3 liter.
Mar 29, 2009 at 10:07 AM
MERLIN2021
  • 17,250 POSTS
If you dont need it, dont use it! Use the one designed for your car, or you are asking for trouble...
Mar 29, 2009 at 11:00 AM
DEVINTHEREAPER
  • 5 POSTS
[quote:b317d8acf5="merlin2021"]Physically the same size, just higher output. With the VIN, call ford and they will tell you which one yours came with. Parts dept![/quote:b317d8acf5]
Is the amperage marked on the alternator anywhere? I plan on buying a used one because new ones are just way to expensive where I live, ( over $200 )
Mar 29, 2009 at 1:18 PM
DEVINTHEREAPER
  • 5 POSTS
how do I find out if i have a 110 amp or a 130 am alternator? Is the amperage marked on the alternator anywhere? I plan on buying a used one because new ones are just way to expensive where I live, ( over $200 )
Mar 29, 2009 at 3:15 PM
ZACKMAN
  • 4,202 POSTS
Post the first 8 digits of your VIN number here. I can tell you which one you have.
Mar 29, 2009 at 11:42 PM
DEVINTHEREAPER
  • 5 POSTS
[quote:a7110f72d5="Zackman"]Post the first 8 digits of your VIN number here. I can tell you which one you have.[/quote:a7110f72d5]
1MEFM55U
Mar 30, 2009 at 6:06 AM
MERLIN2021
  • 17,250 POSTS
The info I have is ALL Tarurus and Sables use 130 amp, made by Motorcraft, or Mitsubishi
Mar 30, 2009 at 2:13 PM
ZACKMAN
  • 4,202 POSTS
https://www.2carpros.com/forum/automotive_pictures/55316_98sablealt_1.jpg
Available at rockauto.com.
Mar 30, 2009 at 10:29 PM
MERLIN2021
  • 17,250 POSTS
Zackman, rock auot is showing both 110 and 130 for VIN U?
Go with the 130 amp.
Apr 1, 2009 at 2:10 AM
ZACKMAN
  • 4,202 POSTS
Yes they do. I would agree going with 130 amp as price difference is very small.
Apr 2, 2009 at 10:38 PM
