1997 Mercury Sable Window washing issues
1997 MERCURY SABLE
122,000 MILES • 6 CYL • FWD • AUTOMATIC
HANDBALL21
  • 6 POSTS
My window washing system has died. The wipers used to come on when pushing the button and the fluid barely covered the drivers side window. Now, when I push it the wipers don't come on at all and no fluid at all. Is this a problem in the switch/turn signal device or pump?
Oct 26, 2010 at 9:37 AM
It could be either. However, it sounds more like the switch. What you need to so is check to see if there is power to the washer motor. It is located at the bottom of the W/S washer resivour. If there is power, then the motor is bad. If there is no power, then you have to move to the switch.
Let me know what you find.
Oct 26, 2010 at 10:32 AM
HANDBALL21
  • 6 POSTS
The fact that it sorta worked until recently - a had low water pressure that was only capable of spitting water on one side of the windshield - any clue?
Oct 26, 2010 at 10:55 AM
Either the motor is bad or the hoses are plugged. Can you hear the motor run?
Oct 26, 2010 at 1:20 PM
