For 3.0L OHV Engines:
First pass: tighten the cylinder head bolts in the sequence illustrated to 52-66 ft. lbs. (70-90 Nm), then back off the bolts 360 degrees.
Second pass: tighten the cylinder head bolts in the sequence illustrated to 45-55 ft. lbs. (34-40 Nm).
Final pass: tighten the cylinder head bolts in the sequence illustrated to 63-73 ft. lbs. (85-99 Nm).
For 3.0L DOHC Engines:
Tighten the bolts, in sequence, to 28-31 ft. lbs. (37-43 Nm)
Rotate the bolts, in sequence, 85-95 degrees
Loosen the bolts, in sequence, a minimum of one full turn
Rotate the bolts, in sequence, an additional 85-95 degrees
Thanks for using 2CarPros.com !
Jan 24, 2009 at 11:34 PM
