1996 Mercury Sable NO BRAKE PEDAL
1996 MERCURY SABLE
14,000 MILES • 6 CYL • FWD • AUTOMATIC
JERSEYJACK
I REPLACED THE FRONT PADS THIS MORNING. AS I WAS COMPRESSING THE PISTON ON DRIVERS SIDE WITH OLD PAD AND C CLAMP FLUID LEAKED FROM MASTER CYL CAP, WHICH USUALLY DOES HAPPEN.
AFTER RELPACING PADS ON BOTH SIDES AND STARTING CAR I CANT GET PEDAL TO STAY UP GOES RIGHT TO FLOOR. THERE ARE NO LEAKS ANYWHERE. PLEASE HELP I AM STUMPED AND NEED CAR. REAR BRAKES ARE ONLY 2 WEEKS OLD.
MASTER CYLINDER STILL FULL.
Dec 21, 2007 at 7:20 PM
BLACKOP555
  • 10,386 POSTS
did you bleed all four brake ports at each tire? also check to see if your pedal is not hooked on the dash or wires.
Dec 21, 2007 at 7:49 PM
JERSEYJACK
PEDAL IS MOVING FREELY, I DIDNT OPEN ANY BRAKE LINES SO THERE IS NO REASON TO BLEED.
Dec 21, 2007 at 8:39 PM
BLACKOP555
  • 10,386 POSTS
still has to be bled, even if the lines wernt opened, when the calliper is all the way out and then is bottomed it can create air bubbles.
Dec 21, 2007 at 8:41 PM
JERSEYJACK
I WILL BLEED IN MORNING AND LET YOU KNOW HOW I MAKE OUT. ILL SLEEP WITH MY FINGERS CROSSED.
Dec 21, 2007 at 9:54 PM
