1996 Mercury Sable Lights stay on
1996 MERCURY SABLE
140,000 MILES • 6 CYL • 2WD • AUTOMATIC
TROSHIP
My headlights will not go off. I turned the auto dimmer switch off, and when i did that, the high beam light remains lit and the headlights on. I started and restarted the car with the same results. Help?!?
Feb 24, 2009 at 8:29 PM
2CARPRO JACK
  • 11,533 POSTS
So this vehicle has delayed off on thelights...doe sit have DRL's? (daytime running lights)? I need to know to look up the proper wiring diagram. Also is your Sable a G, GS, LS,?
Feb 25, 2009 at 8:14 AM
TROSHIP
Yes it has daytime running lights, and it is an LS
Feb 25, 2009 at 10:11 AM
2CARPRO JACK
  • 11,533 POSTS
Start by swapping the headlight relay in the underhood fuse/relay center with another realy to see if it is sticking
Feb 25, 2009 at 12:08 PM
