The compressor relay is incorporated into the CCRM (Constant Control Relay Module), also known as the Integrated Controller. It's located on the front radiator support, right above the fan.
Aug 17, 2010 at 7:48 AM
AMBJJR
MEMBER
1 POST
Air Conditioning problem
2002 Mercury Sable 6 cyl Front Wheel Drive Automatic
A/c clutch is not engagig. New compressor and clutch! I read that I may have to jump tje safety switch. Where is it and how might I do this?
Jun 28, 2019 at 6:02 PM
(Merged)
CERTIFIED EXPERT
At the AC clutch solenoid check for power at the black and yellow wire if none test the AC clutch relay-Or do this apply battery voltage to the black and yellow wire and see if it'll engage the compressor.
(Merged)
OIDAVEY
MEMBER
0 POST
I had this problem and replaced the compressor fixed it right up.
