1994 Mercury Sable Where is the A/C clutch relay located?
1994 MERCURY SABLE
95,000 MILES • 6 CYL • FWD • AUTOMATIC
THERE4ME247
I added two cans of R-134A to the A/C. I bypassed the pressure switch and it cooled well. However when I turned off the engine and turned it back on, the pressure clutch would not engage. Could it be a faulty clutch relay? If so, where is it located? Thanks!
May 5, 2010 at 8:28 PM
BLUELIGHTNIN6
  • 16,542 POSTS
check the constant control relay module output voltage, check between CCRM connector terminals #16 and #23. if 10 volts or more then there is damaged wiring between clutch coil and CCRM. also check fuse #17 (15 amp).
May 5, 2010 at 8:42 PM
