Engine Cooling problem
1993 Mercury Sable Engine Size unknown Wheel Drive Type unknown Automatic 75000 miles
My daughter bought a '93 Mercury Sable that the person told them had a bad radiator (it had a hole in it)and overheating. I replaced the radiator and the thermostat, but the car is still overheating. It has plenty of coolant in it. When it get hot I can put my hand and the engine is hot, but the top radiator hose is still cool. I replaced the thermostat so I don't think that is the problem. The oil looks clean so I don't think it has a bad head gasket. There are no leaks below the water pump, but could the pump still be bad? A if so, how do I check it? And if that is OK then what could be causing the preblem?
Thanks
Thanks
Mar 4, 2008 at 1:11 PM
