1992 Mercury Sable Turn Signals not working
1992 MERCURY SABLE
BRUCE ANTHONY
Electrical problem
1992 Mercury Sable 4 cyl Front Wheel Drive Automatic 100k miles
Checked fuse, replaced flasher,replaced turn signal switch. Turn signals will not work, 4 way flashers work. Front turn signals work manually (flipping the switch up and down) only when headlights are on. The back will not work at all, and the fronts only with the headlights on.
Dec 11, 2008 at 3:38 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
Thanks for the donation
You need to check the connector pins on the housing that contains the signal switch and the headlight switches that connect to the signal light switch. These pins can come loose fron the circuit board they are soldered to and sometimes need to be repaired or housing needs to be replaced.
Hope this helps..
Thanks for using 2carpros.com!
Dec 11, 2008 at 9:07 PM
