1992 Mercury Sable starter motor will not turn over
1992 MERCURY SABLE
13,865 MILES • 6 CYL • 2WD • AUTOMATIC
DLK777333
Hi! My '92 Mercury Sable will not start. Have power to the headlights and accessories and just replaced starter/solenoid about 4 months ago. Also took new starter to Autozone to test just in case. Car will not jump start either. When try to turn over fuel pump comes on and hear a click above starter somewhere, then nothing. Starter does not click. Any suggestions?What is the best way to troubleshoot?
May 27, 2009 at 4:28 PM
Have helper hold key on starting position check for power at the starter small wire red and light blue/blk wire do you have it-if not check the manual lever position sensor white and pink wire if power is present replace the sensor if not its coming from the ignition switch.
https://www.2carpros.com/forum/automotive_pictures/12900_starter_27.jpg
May 27, 2009 at 5:11 PM
