Engine Performance problem
1989 Mercury Sable 6 cyl All Wheel Drive Automatic
i had my car repaired by a mechanic he replaced the rear valve cover gasket on my 3.0 mercury sable i noticed after i drove it home it was having trouble driving which it wasnt before i took it in the only problem beside my valve cover gasket leaking was my rpm s werent right they would be alittle low not where they normally are at the notch before 1000 any way after driving it 3 times i noticed the kick down cable was off i put it back on but it still hesitates i though it was around where it changes gear but its all through the driving cycle also before i took the car in the rpm werent set right on it they were not on the right mark i wanted them to set that but they didnt know how im trying to figure out if the rpm s problem is causing the hesitation or the tranny because the kick down cable was left off an messed up something
May 27, 2009 at 1:15 AM
