2001 Other Mercury Models from 45-55 mph the car jerks
2001 MERCURY
122,222 MILES • V8 • 2WD • AUTOMATIC
ANGELPREYER
I have had spark plugs & boots changed, fuel injection cleaned and new filter still doing it! jerks in over drive and with over drive off.. is this sumthing major ??
Apr 16, 2010 at 6:08 PM
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Apr 16, 2010 at 6:15 PM
