1987 Other Mercury Models not shifting over 2nd gear
1987 MERCURY
195,964 MILES • V8 • 2WD • AUTOMATIC
CORKY1973JR
My brother & I had taken the top-end off the engine (removing the plenum & fuel rail) to determine the source of a fuel leak. We put it all back together (or so we thought) after we discovered the leak was from the tank itself. Anyways, before the "repair", the transmission worked fine. Afterwards, it won't shift past 2nd gear. I discovered (part of) the problem; an adapter had fallen out from the right rear of the valve cover...which the other end starts under the plenum. I reconnected all this, but I still have no 3rd+ gear. The transmission fluid & filter have been changed (and, btw, the fluid was not burnt, no metal chips in the pan.) NOW, I'm wanting to know if the air pump is at all related to the function of the transmission, and if so, how? Please help me, as I'm going through more gas than can afford.
Mar 19, 2010 at 1:23 PM
HMAC300
  • 48,601 POSTS
check for a disconnected electrical conection or a vacuum line off. Especially since you removed the plenum. The line may be under the plenum so it will be hard to find .
Mar 26, 2010 at 5:42 PM
