1983 Other Mercury Models fuel filter location
1983 MERCURY
JNICKT
Engine Mechanical problem
1983 Other Mercury Models V8 Two Wheel Drive Automatic
I can't find the fuel filter ,where is it?
May 24, 2008 at 2:17 PM
MIKE H R
  • 3,094 POSTS
Depends what model you have. Most newer ones are on the frame under the car by the rear drivers wheel and is attached to the frame. Depending what model it may be further forward on the frame. The only other place the recomment is, if the engine has a carburator it would be in the carb where thwe line goes in.c Follow the lines and you will be able to find it.
May 25, 2008 at 8:51 AM
