1981 Other Mercury Models IGNITION
1981 MERCURY
60,000 MILES • V8 • 2WD • AUTOMATIC
FAIRMONTWATERLOO
MY DISTRIBUTOR HAS A BUILD UP ON THE CONTACTS AND VARNISH ON THE ROTOR TIP . I HAVE REPLACED BOTH AND THE BUILD UP ON THE CAP CONTACTS STARTED AGAIN . IT NOW RUNS ON 7 CYL. BUT I HAVE SPARK AT THE CAP ON ALL . WHEN IT IS WAM IT WILL NOT START
Jul 13, 2009 at 7:52 AM
HMAC300
  • 48,601 POSTS
you probaby have a cracked distributor cap. it is leaking between twocylinders. If you look carefuly inside the cap and see a very fine line going between the two poles that is your problem. In the dealers we used to put dielectric compound on the rotor tip as well as the contact tips in the cap. It will always have the build up that you see though..
Jan 26, 2010 at 5:22 PM
