98 Mystique 2.5L -- moaning noise from under hood!!!!!
1998 MERCURY MYSTIQUE
BASTRAD
I have a 1998 Mercury Mystique with a 2.5L engine. When I start it up when it is cold for the first bit and grab the steering wheel and turn it a little with vehicle in gear, I get a moaning noise coming from the air box. It only happens when it is at first warmup time. Then it disappears when the engine is completely warm. Any ideas of what that would be.
Jan 9, 2006 at 11:01 AM
SHAUN_GA
try the power steering pump
Jan 10, 2006 at 8:24 AM
BASTRAD
The power steering pump is on the opposit side (Pass. side) of the the air box (where the air filter is placed) and that is on the drivers side. Any oter suggestions?
Jan 10, 2006 at 10:51 AM
COSMO
  • 347 POSTS
it is most likely the IAC motor...these will make a howling noise when cold, or if they get bad enough...you can make it do it by short quick accelerator jabs
Jan 10, 2006 at 11:42 AM
