1998 Mercury Mystique no power to the starter?
1998 MERCURY MYSTIQUE
142,227 MILES • 6 CYL • 2WD • AUTOMATIC
BIRDMANN93
I got power everywhere but the starter when I turn the key nothing happens not even a sound
May 12, 2010 at 8:47 AM
INTERNETMECHANIC
  • 700 POSTS
Do you think the security system is causing a problem? You can check voltage circuits to the starter relay. Usually voltage to the load side of relay is hot all the time, voltage to the coil side of relay goes hot with key in the crank position. Ground for the coil side of relay, automatic, goes through the trans range sensor, then where applicable, through the theft module.
https://www.2carpros.com/forum/automotive_pictures/512072_mercury_starter_circuit_1.jpg
May 12, 2010 at 11:32 AM
THIS IS MIKE
  • 686 POSTS
Replied on May 12, 2010
ignition switch is probably shot, try jumping starter. if starter cranks then suspect faulty switch.
Answered by bluelightnin6 (expert)
17,236 answers provided
Jun 5, 2013 at 2:38 PM
