your car is a 2.5 right ? just want to make sure. is not, just let me know.
we start with the loc of the starter.
here should be the removal:
Disconnect the negative battery cable.
Remove the engine air cleaner assembly.
Remove the fuel feed and return lines from the support bracket located on the accelerator cable bracket, and remove the fuel line bracket.
On your vehicle with a automatic transaxle, remove the gear selector and the gear shift cable bracket from the transaxle.
Remove the air cleaner support bracket from the engine and transaxle mount.
Remove the nuts on the starter terminals and remove the cables from the terminals.
Remove the starter motor-to-transaxle case retaining bolt at the rear of the starter.
Remove the two starter retaining bolts and carefully lift the starter from the transaxle case while disengaging the alignment pins.
installation
Position the starter onto the alignment pins and onto the transaxle case.
Install the two starter retaining bolts and the rear retaining bolt and tighten them to 15-21 ft. lbs. (21-29 Nm).
Place the starter cables onto the terminals and tighten the retaining nuts to 80-124 inch lbs. (5-7 Nm).
Install the air cleaner support bracket.
If removed, install the gear shift selector and bracket.
Install the fuel line bracket and install the fuel lines in the bracket.
Install the air cleaner assembly.
Connect the negative battery cable.
hope you got the help you need. ask if you have questions.
Oct 2, 2009 at 4:06 PM
