Front pads:
Removal & Installation
Before servicing the vehicle, please familiarize yourself with safety procedures.
Remove the brake pads.
Remove and discard the 2 brake caliper anchor plate bolts.
Remove the brake caliper anchor plate.
To install:
Installation is the reverse of the removal procedure.
Observe the following anchor plate bolts tightening torques:
Aviator 155 ft. lbs. (210 Nm) 2002 Explorer and Mountaineer 83 ft. lbs. (112 Nm) 2003-05 Explorer and Mountaineer 100 ft. lbs. (136 Nm)
Lubricate the brake caliper guide and locator pins with silicone grease.
Rear Pads:
Disconnect the rear parking brake cable guide.
Remove the axle shaft.
Remove the bolts and the rear wheel disc brake adapter.
To install:
Torque the adapter bolts to 80 ft. lbs. (108 Nm).
Mar 23, 2009 at 9:22 PM
