Electrical problem
2003 Mercury Mountaineer 6 cyl All Wheel Drive Automatic
I have replaced the window lift motor and the window switch to the front passenger door. The window still does not go up and down. I tried them in the rear door and they work there. If the switch in the driver door was bad, would that cause the window motor not to work? What else to I need to check?
All windows work from master switch and I have not seen any exposed wires. I have not checked with a meter, just visual. I was wondering if master switch could be bad, or if there is a fuse or relay to check?
Aug 15, 2010 at 8:30 PM
