2003 Mercury Mountaineer Air cabin filter
2003 MERCURY MOUNTAINEER
EBADOO16
Is there a cabin air filter on this model? If so, where is it located. I have a musky smell that blows out of the A/C unit, more so if I use the max air setting. What is causing this? Can something get into the air system and keep causing a smell?
Sep 21, 2008 at 1:20 AM
2CARPRO JACK
  • 11,533 POSTS
My software doesnt show a cabin filter for that one.IS it losing any coolant with no visible leaks? If so you may have a leaking heater core. Otherwise try using Ozium to kill theodor, run thenormal a/c seting and spray it in at vent at base of windshield, then turn to heat and spray, then to MAX a/c and spray at floor, this will cover the entire system
Sep 21, 2008 at 9:15 AM
