2002 Mercury Mountaineer Overheating engine
2002 MERCURY MOUNTAINEER
CDMANN617
Engine Cooling problem
2002 Mercury Mountaineer 6 cyl All Wheel Drive Automatic
My vehicle constantly runs hot. I have replaced the radiator, thermostat, water pump, and checked all the fans and it is still running hot. There is no water pressure coming to the thermostat. When I remove the thermostat there is no water there. When I start it up and put coolant in it, the water comes up to the thermostat. Then when I run it, it starts running hot again. I have replaced everything that has anything to do with the cooling system. There seems to be no water coming up to the thermostat like it should. What could be causing this?
Aug 13, 2010 at 9:44 AM
Check the water pump again and the hoses if its collasped
Aug 14, 2010 at 6:38 AM
CDMANN617
My vehicle constantly runs hot. I have replaced the radiator, thermostat, water pump, and checked all the fans and it is still running hot. There is no water pressure coming to the thermostat. When I remove the thermostat there is no water there. When I start it up and put coolant in it, the water comes up to the thermostat. Then when I run it, it starts running hot again. I have replaced everything that has anything to do with the cooling system. There seems to be no water coming up to the thermostat like it should. I have checked the hoses and the water pump again and the hoses aren't collapsing and the water pump is fine. What could be causing this?
Aug 17, 2010 at 1:38 PM
Check the radiator if its clogged by feeling for cold spots-if okay try bleeding it and see what happens
Aug 17, 2010 at 2:02 PM
CDMANN617
My vehicle constantly runs hot. I have replaced the radiator, thermostat, water pump, and checked all the fans and it is still running hot. There is no water pressure coming to the thermostat. When I remove the thermostat there is no water there. When I start it up and put coolant in it, the water comes up to the thermostat. Then when I run it, it starts running hot again. I have replaced everything that has anything to do with the cooling system. There seems to be no water coming up to the thermostat like it should. I have checked the hoses and the water pump again and the hoses aren't collapsing and the water pump is fine and the radiator has been checked. We realize that the heating hose is causing pressure to build up. Once the pressure is let off it stops running hot for about a week then does it again. What could be causing this? How can it be repaired?
Aug 19, 2010 at 2:13 PM
Could be a blockage in the block coolant passages try flushing the cooling system
Aug 19, 2010 at 4:29 PM
