I have just replace the front differential. One month ago, I had two tires replaced and an oil change on a Saturday, and while i was on the road later that day she broke down on me. Evidently there was a gear oil leak and when too much had leaked the front differential locked up. Now that we have swapped it out, my car is pulling to the left. I took it in to check the alignment but was told that was not the problem, I was told it had something to do with the differential or possibly an axle. I am not sure if it is relevant, but I want to mention that the two front tires had been replaced and were slightly wider than the rear tires. Once I replaced the differential, I rotated the wider tires to the rear and now my car is pulling to the left and it feels like the AWD is struggling. Not to mention I am getting six to seven MPG now. Also, when I make a sharp left turn there is a pop, or what sound likes like possibly a bad bearing or ball joint. Not sure. Can you help?
Aug 5, 2008 at 3:08 PM
