2000 Mercury Mountaineer differential????
2000 MERCURY MOUNTAINEER
TBOARD
Noises problem
2000 Mercury Mountaineer Four Wheel Drive 146000 miles
my suv makes a loud humming noise,the more i accelerate the louder it gets, also when i put it in reverse and start to bac up its like something is grabing it trying to hold it bac, a mechanic told me it was my differential but i want a 2nd opinion before i spend alot of money
Nov 11, 2009 at 2:46 PM
RICKMAR
  • 170 POSTS
Have you changed your differential fluid at some point during the 146,000 miles driven?
If you have not... I would do a flush and fill.
If the problem persists then something needs to be replaced gear wise.
I hope it is just a flush and fill.
If you have a limited slip differential which I am quite sure you do, make sure you add the adhesive additive in the "rear" only.
Good Luck;
Rick
Nov 13, 2009 at 9:25 PM
