clutch sticks to the floor ?
2006 MERCURY MILAN
48,500 MILES • 4 CYL • 2WD • MANUAL
SNOWKYLEGC
My 2006 Mercury Milan 2.3L 4 cyl. 5-speed manual clutch sticks to the floor when i press it. I can put it in gear as soon as i push it in, but then it tries to take off after a couple seconds while the pedal is still on the floor. Also I noticed when I barely press the pedal about 1/3 the way down, it pulls itself the rest of the way to the floor. What does this sound like?
Jul 15, 2009 at 2:54 PM
DOCFIXIT
  • 18,828 POSTS
This sounds like the clutch master is no good and needs to be replaced. Here is a diagram to help you get the job done. Once the master is installed just pump the clutch pedal which will bleed the system for you.
Jul 15, 2009 at 3:03 PM
