rear window glass removal
MERCURY MARQUIS
COFFEECLUBBER
Apparenty I did not make myself clear on the previous question on how to remove the rear door
glass so I can remove the regulator.Its a 95 Merc.
grand Marquis.I have the glass loose from the regulator but it has to come completely out of the frame before I can remove the regulator.Even the shop manual does not tell how to do this.Possibly the weather strip has to be removed.
Jan 30, 2007 at 6:02 PM
MERLIN2021
  • 17,250 POSTS
There are 2 bolts that look more like flat washers with holes in them unscrew these and you should be set.
Mar 6, 2007 at 7:05 AM
COFFEECLUBBER
[quote:7f8b5e2a2b="merlin2021"]There are 2 bolts that look more like flat washers with holes in them unscrew these and you should be set.[/quote:7f8b5e2a2b]
Those bolts do not unscrew,they are riveted in.
I finally got in there with a Dremal tool and ground
them off with a small stone.Then I was able to remove the regulator. I drilled the same bolts off of the new regulator and welded 1/4 inch nuts in their
place.then bolted the new regulator in with 2 new
1 inch bolts.I didnt have to remove the glass at all this way.
Mar 6, 2007 at 3:44 PM
MERLIN2021
  • 17,250 POSTS
OK! I guess they changed the design from bolts to rivets.
Mar 6, 2007 at 3:52 PM
