2006 Mercury Marquis venting
2006 MERCURY MARQUIS
73,000 MILES • V8 • 2WD • AUTOMATIC
NAMVPL
the air only comes out of the defrost and floor when the ac is on.
also the mph does not in info window in center of dash any more like it used to.
also the right turn signal goes fast and i checked and both front and back lights where blinking.
Jun 1, 2010 at 1:52 PM
2CARPRO JACK
  • 11,533 POSTS
Need to know what Marquis you have GS, or LS. IS the climate control automatic or manual? The MPH may be a selection on the dash info center, otherwise if the trans shifts properly you may have a bad dash cluster. Turn signals, turn on left signal and compare the rear lights with right turn to see if there is supposed to be 2 bulbs flashing, if one of them is out it will cause a fast flash, same goes for front, see if maybe the side marker light is out causing the fast flash
Jun 4, 2010 at 8:30 AM
NAMVPL
LS Ultimate
Jun 4, 2010 at 11:05 AM
2CARPRO JACK
  • 11,533 POSTS
Sorry for the delay in getting back to you.You will need toput theautomatic a/c system in self-diagnostic mode.
Turn key on, engine off
Press Floor and off at the same time, within 2 seconds press the automatic button.
It will show a tracer going around the display window, it may take up to 30 seconds for it to do thetest, but it should spit out nay codes it has stored, they should tell us what is wrong
Jun 6, 2010 at 9:03 AM
NAMVPL
turned car on engine off pressed the floor button and off at same time and then pressed auto button
then the little dash mark goes around. then it lights up with 888 in the middle and flr, max, ac, vent etc around it. does the number 888 mean anything?
Jun 7, 2010 at 8:32 AM
2CARPRO JACK
  • 11,533 POSTS
How long did it take for that to come up? that is the system exiting self test, according to Mitchell it shouldnt go to that screen unless you push the defrost button, which will clear any codes that may have been in there.This may be an issue with the module, does it only act up when the a/c is on and not the heat?
Jun 8, 2010 at 8:16 AM
2CARPRO JACK
  • 11,533 POSTS
Also check under the hood for any broken vacuum lines that go to the firewall, sometimes these systems will mix vacuum and electric for the controls
Jun 9, 2010 at 8:28 AM
