2004 Mercury Marquis how to determine if catalytic converte
2004 MERCURY MARQUIS
PLAD2CARPROS
Noises problem
2004 Mercury Marquis V8 Two Wheel Drive Automatic 99k miles
in an earlier post and reply it was suggested i bang the converter with a rubber mallet to see if the heat shiled is loose vs the converter being bad - stupid question but once i do this how do i interpret the sound (i hear a slight buzzing or tinging after i bang on it)
Nov 4, 2009 at 4:51 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
Yes this is a bit difficult to determine, normally a heat shield will be a tinny sound and a failed core of the converter if broken away will be a more solid rattle, as the core is of a honeycomb construction it will break up into sizable lumps and this will give a heavier sounding rattle
mark (mhpautos)
Nov 5, 2009 at 12:02 AM
