1999 Mercury Marquis Water coming out of the top of the eng
1999 MERCURY MARQUIS
CSYWLLMS
Engine Cooling problem
1999 Mercury Marquis V8 120000 miles
My check engine light came on then the car started running hot. I had the thermostat replaced and later that same day it ran hot again and started smoking from under the hood. When I opened the hood and removed the cover from the motor, there was a crack at the top right side and water was running out of the crack like a faucet. What should I get repaired?
Nov 30, 2008 at 11:51 AM
VOLTS
  • 16 POSTS
Hi
Well I hate to break the bad news too you, but it sounds like you have a cracked engine block, as far as I know the only thing that can be done is replace the engine, I have heard of some cases where a crack can be welded, but I would not count on that.
Jan 4, 2009 at 10:22 AM
302ERNIE
  • 9 POSTS
THESE HAD A RECALL FROM FORD IT IS THE INTAKE MANIFOLD THEY WHERE MADE FROM PLASTIC AND LATER UPDATED
Jan 30, 2009 at 2:37 PM
