1999 Mercury Marquis axel wear
1999 MERCURY MARQUIS
11,523 MILES • V8 • 2WD • AUTOMATIC
BUDDYROE
I recently noticied my rear axel leaking oil on to my concrete at my house .And i put my car on the hoist and removed the axel and noticied that the bearing worn a groove about 16th of an inch onto my axel shaft on the drivers side from lack of oil.I wanna know is there a offset/or a repair bearing that I can replace my axel bearing with so I can use my same axel so hat it will not put wear onto the same location as my factory bearing did.Thank you
Aug 8, 2008 at 5:40 PM
BLACKOP555
  • 10,386 POSTS
put on a new axleshaft, arnt too expensive, that way your not messing with the weakened drive shaft, could have lost the temper due to the heat.
Aug 8, 2008 at 8:26 PM
