1997 Mercury Marquis heat from vents
1997 MERCURY MARQUIS
246,000 MILES • V8 • 2WD • AUTOMATIC
HIGHSTRAIGHT
I have a/c that works. I have vent that works.
No defog and heat that comes from the vents.
This is the same thing that happens in a 2005
I know. Must be common.
Sep 13, 2010 at 2:52 PM
WRENCHTECH
  • 20,761 POSTS
Are you saying that the mode control doesn't switch the air flow to defrost or bottom vents?
Sep 13, 2010 at 3:13 PM
HIGHSTRAIGHT
In defog mode, there is no output. In heater mode, heated air comes out the vent. A/C and vent modes are fine.
Sep 13, 2010 at 6:06 PM
WRENCHTECH
  • 20,761 POSTS
The mode control doors on that car are vacuum operated. First check that all the hoses are hooked up and nothing is jammed. If it's an Auto temp control system. there is a module that controls the vacuum. If it's manual, there is a vacuum rotary switch. Make sure you have a full vacuum supply coming in from the engine on the black hose. Measure the vacuum and compare it with manifold direct vacuum.
Sep 13, 2010 at 6:11 PM
