I am attaching the info below on this including the wiring diagrams. Please run through this and let us know what you find.
If you have no voltage from the LCM then we need to replace it.
Jun 11, 2009 at 5:54 PM
J PERINOVIC
MEMBER
1 POST
Brakes problem
1997 Mercury Marquis 112000 miles
where is the flasher located 1997 grand marquis
Jan 3, 2020 at 3:16 PM
(Merged)
SERVICE WRITER
CERTIFIED EXPERT
Right rear of the trunk.
(Merged)
STEK
MEMBER
1 POST
Where Is The Turn Signal Flasher when it is not in the fuse box under the left side of the dash on a 1996 Mercury Grand Marquis?
(Merged)
BLUELIGHTNIN6
CERTIFIED EXPERT
The Turn Signal Flasher output is provided by the Lighting Control Module, which is located behind the LH side of the instrument panel. There are no separate relays for Turn Signal Flasher output aside from the LCM.
