Dry ball joint and or outer tie rod end is a common noise maker when turning (have them check )
since they don't come with grease fitting they need to be replaced
if its happens only when turning and at the end of the turn
check and grease contact point between lower control arm and spindle
Jun 11, 2010 at 5:58 AM
