Having a problem with my 1996 Mercury marquises turn signal. If I engage the turn signal completely(left or right turn) where it will automatically return to neutral position. It doesn't work! If I engage the turn signal partially where the Arrow on the panel is just illuminated and blinking it works fine. The owner's manual shows the plug-in Flasher located under the dashboard with the fuses. But it's not their, just a vacant slot. Had local mechanic check , and he indicated the Flasher was located in a separate module that cost close to $350. Since the turn signal works when I do not completely engaged it , could it be something other than this expensive module?
Jan 22, 2006 at 2:28 PM
