The rear of vehicle lowered almost to the ground .
It has air bladders instead of springs. We tested the compressor and is working fine, I also tried using an air pump to raise it up which didn't help, fuses are not blown, the compressor will not come on . The last time it worked i backed into the lot at work I came out 1 hour later and it was sitting LOW. While backing into driveway over snow and ice ,could something be dislodged at the back end ???
Feb 18, 2008 at 4:19 PM
