1995 Mercury Marquis ignition
1995 MERCURY MARQUIS
90,000 MILES • V8 • 2WD • AUTOMATIC
FRANDES
car would not shut off with ignition key, key could be removed, remove fuse to fuel pump and battery terminal to shut off car. replaced key locj cylinder. did not correct problem. All dash light indicators stay on when battery is reconnected. not sure if replacing ignition switch is the answer? Seems like something mechanical from key to switch. Please advise
May 16, 2009 at 5:47 PM
IT sounds like the switch is out of adjustment or bad. That is where I would look next.
May 23, 2009 at 2:38 PM
