1994 Mercury Marquis Low clicking (clacking) noise
1994 MERCURY MARQUIS
140,000 MILES • V8 • FWD • AUTOMATIC
NATHAN08T
  • 14 POSTS
Well, when I accelerate I hear a very light faint clicking noise. When I hit about 35 I can feel the car shift and if I don't let off the gas for a brief moment I can hear a low clicking/clanking noise coming from the engine. I have to let off the gas for a second or else the car won't accelerate (Unless I just hammer on it). Any advice?
Mar 12, 2009 at 12:33 AM
Has the check engine light come on?
May 23, 2009 at 3:23 PM
NATHAN08T
  • 14 POSTS
Yes, but only when the car starts to idle at above normal speeds.. Sometimes it sounds like the car has knocking rods? It was ran with the oil light on for a short distance.. 10~ miles about
May 23, 2009 at 7:01 PM
If the light comes on, there is a trouble code saved in the computer. If you take it to a nationally recognized parts store, they will scan it and let you know where the problem is coming from. Most will do it for free.
Let me know what they tell you. As far as the noise you hear, let me know what the code is. A sensor may be causing the problem.
May 23, 2009 at 11:46 PM
NATHAN08T
  • 14 POSTS
I just got back from O'Reillys, there were two tests, KOEO and KOER. The first one I did was KOEO. It gave me four error codes.
111 - System Pass
125 - Throttle lower than expected
332 EGR flow insufficient
337 - EGR valve position or exhaust pressire transcendent circuit above max voltage
The KOER gave me just one,
332 - EGR flow insufficient.
I'll look around online to see what those mean but hopefully you can give me some insight on what all this means.
Thanks in advance!!
May 30, 2009 at 7:57 PM
NATHAN08T
  • 14 POSTS
Any help? =(
Aug 8, 2009 at 10:29 AM
NATHAN08T
  • 14 POSTS
Does anyone have any information on this? Is there any place where I could find a diagram on the location of the EGR valves? I tried to find some online but I couldn't =/
Jun 12, 2010 at 12:28 AM
