1993 Mercury Marquis check engine light
1993 MERCURY MARQUIS
RANGERJ
  • 17 POSTS
Engine Performance problem
1993 Mercury Marquis V8 Two Wheel Drive Automatic
I used to be able to push the odometer button and turn the switch on a honda and the light would go out. this info came from the dealer. How can i make the check engine light go out on this car. it runs fine and has no noticeable problems thanks
Oct 31, 2008 at 3:12 PM
The computer has identified a problem within the engine management system-you need to have it scan for OBD1 code/s to find out what's causing the the light to come On this is the starting point-
Oct 31, 2008 at 3:32 PM
RANGERJ
  • 17 POSTS
thanks
Oct 31, 2008 at 3:34 PM
