1993 Marquis air suction noise
1993 MERCURY MARQUIS
HAWKKEY
1993 mercury grand marquis, v8 4.6l, auto trans. approx. 125,000 miles.
The problem is a noise coming from a vaccum source. The is a 1 inch diameter hose coming from the intake manifold going towards the rear and under side of the car (towards the Tranny). This hose has a periodic noise that sounds like a fog horn, if I increase rpm I can make it go away, it generally is noticable at low speeds or idle, I can pull it off and plug with my finger and sometimes cause it to happen, almost sounds as though it is a split in this hose and is causeing an air suction vibration. Any thoughts
Jul 9, 2007 at 9:18 AM
PZOHIMSKY
did you ever find the problem? I have the same thing happening.
Jan 1, 2009 at 8:58 PM
