1992 Mercury Marquis fuel pump fuses
1992 MERCURY MARQUIS
16,200 MILES • V8 • 2WD • AUTOMATIC
CLUDEE
the fuse on my fuel pump keeps blowing out when the car is starting this is a 1992 grand marguis has ran very well i would like to keep it.
Dec 11, 2007 at 5:02 PM
Do you have a repair manual? if not see below-If so find the fuel pump relay in relay center on left side of engine compartment and remove it-now put a new fuse On did it blow?
Dec 11, 2007 at 5:41 PM
CLUDEE
[quote="cludee"]Other Category problem
1992 Mercury Marquis V8 Two Wheel Drive Automatic 16200miles
the fuse on my fuel pump keeps blowing out when the car is starting this is a 1992 grand marguis has ran very well i would like to keep it The engines 4.6liter is quiet. Can you hepl me with this.
Dec 11, 2007 at 7:35 PM
This problem is not a very simple thing to fix over the internet. You have a short somewhere within the fuel pump circuit-check the fuel pump relay/inertia cut off switch,fuel pump and wiring.
If you are a DIY with no electrical experience-you need to bring it in. You might end up making things worst then it is.
Dec 12, 2007 at 12:55 PM
