1991 Mercury Marquis Ignition lock cylinder
1991 MERCURY MARQUIS
150,000 MILES • V8 • 2WD • AUTOMATIC
JDWCOBRA93
I am trying to replace the ignition lock cylinder. My problem is that the key won't turn the lock cylinder anymore, so I can't push the button on the underside of the switch to remove it. How can I remove it with out being able to turn the cylinder?
Dec 27, 2007 at 4:12 PM
BMRFIXIT
  • 19,053 POSTS
[quote:e65eb6adec="jdwcobra93"]Other Category problem
1991 Mercury Marquis V8 Two Wheel Drive Automatic 150000 miles
I am trying to replace the ignition lock cylinder. My problem is that the key won't turn the lock cylinder anymore, so I can't push the button on the underside of the switch to remove it. How can I remove it with out being able to turn the cylinder?[/quote:e65eb6adec]
drill the cylinder lock
use a screw driver to turn it
Dec 27, 2007 at 5:03 PM
JDWCOBRA93
how and where do I need to drill it?
Dec 27, 2007 at 5:25 PM
