my ignition module went out and was recently replaced. after the replacement of the module the car started to lose power whenever i went up a hill which would cause the lights to flicker as the car struggled up the hill wen getting on flat ground the car worked fine as normal i changed the spark plugs, cap, rotor, and installed new plug wiring but still have the same results going up hill even though the flat ground performance has improved where should i start next
Mar 23, 2010 at 7:34 PM
