1985 Mercury Marquis Cutting off while stopping
1985 MERCURY MARQUIS
GIJB2
  • 4 POSTS
Engine Performance problem
1985 Mercury Marquis V8 Two Wheel Drive Automatic
as you can see i have a 1985 grand marquis and it cuts off when i stop a a stop sign or red light. It also shuts off when i put it in reverse. my cousin thinks its a clogged fuel injector. what do you think? would a clogged fuel injector do that or could there be another problem?
May 30, 2010 at 9:14 AM
Many things can do it, plugged fuel filter, vacuum leak, needing a tune up, low fuel pressure... Has the check engine light ever come on?
Jun 9, 2010 at 9:26 PM
GIJB2
  • 4 POSTS
[quote:e7323c7163="Jacobandnickolas"]Many things can do it, plugged fuel filter, vacuum leak, needing a tune up, low fuel pressure... Has the check engine light ever come on?[/quote:e7323c7163]
no the light hasnt came on, i changed the filter last year got a tune up in summer of 08, i also forgot to say it backfire a little.
Jun 9, 2010 at 11:16 PM
If you are getting a back fire, first I would check for vacuum leaks. Also, does it seem any worse when it is damp outside?
Jun 10, 2010 at 7:17 AM
GIJB2
  • 4 POSTS
[quote:8eb1d790a4="Jacobandnickolas"]If you are getting a back fire, first I would check for vacuum leaks. Also, does it seem any worse when it is damp outside?[/quote:8eb1d790a4]
no not really. it seems to run good for a short period but then starts acting up.
Jun 10, 2010 at 10:27 PM
