Front end noise
2010 MERCURY MARINER
11,000 MILES • 6 CYL • AWD • AUTOMATIC
JULIEC
My 2010 Mariner makes loud clicking noises when making turns on hot days only. What could be causing this to happen?
Jul 9, 2010 at 11:08 AM
DOCFIXIT
  • 18,828 POSTS
I have seen the front bearing hubs go out on these cars here is a video of a hub bearing being done on a similar car, the process is the same. There are diagrams and instructions below to show you on your car.
https://youtu.be/_FzmmBoa4Tg
Jul 9, 2010 at 2:54 PM
HLACEFIELD
Thank you for this post, I had this problem and had to get the bearing replaced cost me $350.00 all fixed!
Feb 21, 2019 at 3:29 PM
MACGBE
I just replaced the following:
1. Tie rod ends (right & left)
2. Front wheel bearings (only-not the entire hub assbly) both sides
3. Both struts
After 3 days it started vibrating ( I can feel it thru the steering wheel and when I brake. Brakes and rotors were replaced only 1,000 miles ago. As time progresses the brakes are getting loud also
Frustrated as He#@!!!!
Please help!
Thanks
BMac
Feb 21, 2019 at 3:30 PM (Merged)
CARADIODOC
  • 34,306 POSTS
The first thing to look at is putting the wheels back on. It's critical to use a click-type torque wrench and the lug nuts must be tightened to the specified setting. Uneven tightness causes uneven clamping forces. With repeated heating and cooling cycles that leads to warped rotors.
New rotors also often warp, especially those made in China. There's nothing wrong with how they're made but when we make parts out of cast iron we let them age 90 days before they get their final machining. The Chinese parts are cast, packed, and shipped right away, then they age on your car. Usually one light machining by the shop that did the brake work is all that's needed and is nothing out of the ordinary.
