1985 Mercury Lynx How to replace a timing belt in 1985 Merc
1985 MERCURY LYNX
CBRADEN
Engine Mechanical problem
1985 Mercury Lynx Manual
My son is without transportation to and from work and someone is offering to give him a 1985 Mercury Lynx. The catch is that it has a broken timing belt. They have the belt to give us and my son has a great deal of mechanical ability but has never replaced a timing belt. Also, I have read that there is a possibility of engine damage in this car if the belt breaks, which is why they recommend that it be replaced at 60,000 miles. Is there any way of telling if the engine has been damaged before changing the belt? Can you give us some direction or instructions on changing it? Can you provide diagrams that will help? We don't have much but do have a desire to succeed and any help would be greatly appreciated. Thank you!
May 17, 2009 at 6:12 PM
RACEFAN966
  • 5,029 POSTS
Ok what I would do is remove the drive belts and stuff and then remove the timing cover and set your timing marks right (refer to pics below). Then put the belt on and then start it (only for a few seconds). If it starts then shut it back off and finish putting it together. If it don't start then do a compression test on it and go from there. I would also check the local library to see if they have a repair manual that you can use so that with that and myself you can put this back to gether and have it runnig.
https://www.2carpros.com/forum/automotive_pictures/249564_Graphic_85.jpg
Releasing the Tensioner
https://www.2carpros.com/forum/automotive_pictures/249564_Graphic1_11.jpg
May 18, 2009 at 10:09 AM
CBRADEN
Thank you! We'll let you know if we hit any snags or how it goes.
May 18, 2009 at 11:57 AM
RACEFAN966
  • 5,029 POSTS
Ok sounds great. If you have any questions please just ask.
May 19, 2009 at 9:05 AM
