I have a pre-march 1999 mercury cougar with a DOHC 2.0 zetec motor with VCT, The check engine light came on one day after it started to run really bad, it would hesitate and felt like the timing was being retarded. I checked the timing belt and it was missing a bunch of teeth and about to break. I changed the belt using the cam alignment tools and put it back together, I started to drive it and it started chugging again and the check engine light came on. My question is how do you reset the sprocket with the variable cam timing, I loosened the sprocket retaining bolt on each sprocket and retightened them with the cams aligned, when I rotated the crank around twice, the cams didn't line up that anymore, they weren't that far off, but it was far off enough to make the car run bad, I can't seem to get it just right. Thanks pete
Mar 19, 2007 at 7:07 PM
