2002 Mercury Cougar Botched repair, or simple mistake?
2002 MERCURY COUGAR
65,000 MILES • 6 CYL • FWD • AUTOMATIC
SNURFLE
I was in a wreck in September and had some work done to the front end.
Specifically, new tires in the front, tie rod ends, and an alignment in addition to some body work.
I was out of state for 2 months and did not drive the car during that time.
Since then, I have driven on the ice and snow which just recently started to melt away, and I noticed that both tires (new) are bare on the outer edges, but full tread toward the inner edges.
I took a longer harder look, and with the car sitting on the pavement, I could see that the front tires formed a "V"; both of them tilted away from the car on top, toward the car on the bottom.
Despite this, the car drives in a straight line with hands off the steering wheel (both tires off the same amount in opposite directions?) although it is very noisy whenever I hit a bump in the road.
I took the car back to the repair shop that did the repairs in September, and they told me that the rack/pinion was bad, and that they didn't check that when they did the initial repairs.
Now they are telling me that they will have to replace about $500 worth of 'stuff', plus labor, at my expense, in addition to charging me for another alignment, and they need to replace the tires as well.
The owner of the shop told me that the alignment was off "four degrees", and that he had never seen an alignment off this far ever before. I am not sure what that actually means.
I feel that they should have noticed this when they did the initial repair and had it covered under the insurance claim.
Now, however, they had already done an alignment before the insurance claims adjuster looked at the car, and insurance is refusing to cover the cost of the tires (which is the ONLY thing the repair shop submitted.), claiming that tire wear due to a bad alignment is simple maintenance and not covered by my policy.
My question is this... Should the rack/pinion have been looked at during the course of the repairs in September, or is that something that is easy to overlook?[img:3c171a421e]http://www.2carpros.com/forum/automotive_pictures/498406_redlined_1.jpg[/img:3c171a421e]
[img:3c171a421e]http://www.2carpros.com/forum/automotive_pictures/498406_closeup_1.jpg[/img:3c171a421e]
Mar 10, 2010 at 6:38 PM
BLACKOP555
  • 10,386 POSTS
if the rack and pinion was that bad off they would have known it. when they did the alignment it should have been spot on. and if the rak and pinion was bad it would have been off.
secondly rack and pinion affects the toe. not the camber which is a issue you have. that is caused by strut angle and ball joint and control arm positioning. rack and pinion does not affect it at all. they are blowing smoke out of their you know what.
Mar 11, 2010 at 8:59 AM
