2000 Mercury Cougar weird electrical issues
2000 MERCURY COUGAR
BLUELIGHTNIN6
  • 16,542 POSTS
Electrical problem
2000 Mercury Cougar 6 cyl Front Wheel Drive Automatic 123k miles
For the last 2 weeks my gauges peg out (max out) whenever I start my car and my airbag light will also come on and flash sometimes . The flashing airbag light only happens every few times I start the car but the gauges have been pegging out and going back to normal everytime I start it. Also my anti theft light (red light) does not flash anymore (stopped working when the other issues started) and also my interior lights won't turn on most of the time even if the car is started. Alternator/battery both good. I'm thinking body computer? Please help before my only means of transportation to work and college completely dies. I can't afford to pay Ford to check it out at the moment. Thanks in advance!
Oct 25, 2008 at 9:57 PM
MERLIN2021
  • 17,250 POSTS
It sounds like the cluster has a bad solder on the circuit board, you can try resoldering the spots where the harness plugs in. Or change the cluster.
Oct 26, 2008 at 9:26 AM
BLUELIGHTNIN6
  • 16,542 POSTS
No.. I don't think it is that. Everything that I mentioned is all connected to the same problem. They all started the same time and they are all electrical related. The most common factor about them is that they are all illuminated or lit in someway (anti-theft light, doam light, reading lamps, sun visor mirror light, digital clock, digital odometer..etc..) They are not all located in the cluster. It is like when I turn the key off the car loses all of it's electrical powers except for the power seat and power doorlocks. Then if I turn the key over but don't start the car, it regains it's power but it is resetting everything (clock is behind on time, radio resets settings) Except my interior lights still won't work most of the time even if the car is started. But if the interior lights ARE working, then when I turn the car off and restart it the gauges all stay normal. . Confusing , huh? I hate electrical problems .
Oct 26, 2008 at 10:52 AM
BLUELIGHTNIN6
  • 16,542 POSTS
[quote:b9e3e546bc="merlin2021"]It sounds like the cluster has a bad solder on the circuit board, you can try resoldering the spots where the harness plugs in. Or change the cluster.[/quote:b9e3e546bc]
Okay, so it's definitely not the cluster. It is something more major than this. Ford wants $100 just to put it on a computer and run a test. If they don't find anything then I'm out money I don't even have to begin with. You have any other ideas what it might be ? Also, now my anti-theft light is staying on when I take the key out but it is really dim. So instead of it blinking like it is supposed to, or not doing anything like it has been for that past 2 weeks, it is now doing something different. Also, my sound system quit working now. Def. something getting worse. I need to find the problem before it kills power to something that runs the car.
UPDATE: I recently rechecked all fuses and when re-inserting them I pushed a little extra hard to ensure that they are making contact and now all the problems have gone away for the moment. Could it have been as simple as a lose fuse?
Oct 31, 2008 at 7:05 PM
MERLIN2021
  • 17,250 POSTS
Could be a loose wire in back of the fuse box...
Nov 1, 2008 at 12:21 PM
2KCOUGAR
try the battery i had the same issue iwith my 2000 i changed out the battery all the problems left even though my battery was good. you might need to get the keys reprogramed too for the little red light issue or you casn do it your self if you hsve 2 good keys
Nov 10, 2008 at 9:27 AM
BLUELIGHTNIN6
  • 16,542 POSTS
[quote:f683cab317="2kcougar"]try the battery i had the same issue iwith my 2000 i changed out the battery all the problems left even though my battery was good. you might need to get the keys reprogramed too for the little red light issue or you casn do it your self if you hsve 2 good keys[/quote:f683cab317]
Battery is brand new..little red light (anti-theft light) was connected with everything else that had issues. As I already posted, I wiggled around all of the fuses and wires and the issues have went away. Still working fine now.
Thanks though .
Nov 10, 2008 at 12:32 PM
