2000 Mercury Cougar Fuel Pressure Code P0193
2000 MERCURY COUGAR
HUDSPETHK
Engine Performance problem
2000 Mercury Cougar 6 cyl Two Wheel Drive Manual
I am getting a fuel pressure code P0193. The car will start and run smooth up to 1500 RPM's, however anything higher it starts to boag down. I have performed a fuel pressure test at the fuel rail (key on engine off) I hear the fuel pump spinn up up for about two seconds and get a reading of about 20 PSI the book says it should be 37-41 PSI. If I start the engine the reading will jump up to around 30 PSI. I have allso tested the perssure at the fuel filter outlet (New filter) (Key on Engine off) and get about 6 PSI. I have replaced the fuel filter and the fuel pressure regulator($93). Engine compression is good and spark good. I am confussed with the perssure readings i am getting seems like it may be the fuel pump but hate to spend $229 and not have it work. Any suggestions???
Apr 4, 2009 at 4:56 PM
The fuel pump is weak-replace it
Apr 5, 2009 at 7:41 PM
