2000 Mercury Cougar Blown break fuse.
2000 MERCURY COUGAR
114,000 MILES • 6 CYL • FWD • AUTOMATIC
SHARPB1
I installed the European tail lights and had to adjust the wiring in the back. All of the wires are connected but I keep blowing the brake fuse. All of the lights work (running, turn signal, backup) but not the brake lights. They worked for a couple of times but blew the fuse later and every time I replace the fuse it breaks within a matter of seconds. What is causing this break?
Apr 25, 2009 at 8:25 AM
JDL
  • 16,098 POSTS
Hello, does the fuse blow without stepping on the brakes? Maybe the new assembly has a higher amp draw? You might divide the brake system into three sections, high mount--right rear--left rear, check the amp draw on each section, separate from the others. Just a thought.
Apr 25, 2009 at 9:20 AM
SHARPB1
The tail lights have nothing to do with the wires. The wiring system is the exact same one I had before. All I did was cut the running light from my turn signal. the brake lights are fully connected. The car is stuck in park. I am thinking that it is under the shifter because when I hit the brakes, the shifter will not move. I have to manually move the piece to be able to move the shifter and drive the car.
Apr 25, 2009 at 9:25 AM
JDL
  • 16,098 POSTS
Hi, I didn't see anything about the shifting issue in your first post, guess I missed it?
My info shows a brake pedal position switch, works off the same fuse as the brake lite switch.
Apr 25, 2009 at 8:54 PM
SHARPB1
yes, that is true. The same fuse runs the brake lights and moves the lever under the shifter to get the car out of park. I can move that myself to get the car out of park and be able to drive. But i blow the fuse every time and the brake lights do not work. I am just going to get a new wiring set, start from scratch, and take it to a professional so see which wires i can move.
Apr 25, 2009 at 9:56 PM
